[OpenLayers-Dev] [itr@pointcarbon.com: [OpenLayers-Trac] Error in Marker.js]
Andreas Hocevar ahocevar at opengeo.org
Mon Oct 26 16:42:59 EDT 2009
reverted that change due to lack of a better solution.
Regards,
Andreas.
Christopher Schmidt wrote:
> Sent to the wrong list.
> ----- Forwarded message from Ian Trotter <itr at pointcarbon.com> -----
> From: Ian Trotter <itr at pointcarbon.com>
> To: "trac at openlayers.org" <trac at openlayers.org>
> Date: Mon, 26 Oct 2009 17:31:12 +0100
> Subject: [OpenLayers-Trac] Error in Marker.js
> Reply-To: dev at openlayers.org
> Hi,
> The resolution of http://trac.openlayers.org/ticket/2258 seems to have introduced a bug with the event-handling for markers. It seems that the Marker.events property is no longer being set when a marker is initialised.
> As an example, you can see that http://openlayers.org/dev/examples/georss-markers.html no longer shows the markers, with an error message that marker.events is null.
> - Ian
> Trac mailing list
> Trac at openlayers.org
> http://openlayers.org/mailman/listinfo/trac
> ----- End forwarded message -----
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
More information about the Dev mailing list
