[OpenLayers-Dev] Thoughts about #2318: move pink tiles to css
Roald de Wit roald.dewit at lisasoft.com
Mon Oct 26 17:38:21 EDT 2009
Zac suggested using CSS error class names for debugging, but that might
be a bit too fancy for now (this would be a OL wide change). Chris &
Stephen, any idea what the option would look like? We could make it very
flexible by having the option being the URL for the replacement imagd
(blank gif now), so one could show any image on load error.
I'll also look into just removing the bit that sets the src URL. The
drawback will be that in some browsers one won't be able to hide the
broken image (IE6 IIRC).
Regards, Roald
Christopher Schmidt wrote:
> On Mon, Oct 26, 2009 at 11:47:59AM +1100, Roald de Wit wrote:
>> Hi list,
>> During the FOSS4G 2009 codesprint I worked on ticket #2318 [1], which
>> has been committed to trunk. It is now possible to fully control the
>> looks of a broken image using CSS. The change also involves setting the
>> src of the broken image to a blank.gif.  There is one drawback with this
>> last addition: you cannot right-click on the image anymore to see a
>> possible server error (since the src URL has changed).
>  ^^ This is a *huge* problem in my mind. Pink tiles being right clickable
> is a big deal to me, and I'd like to see it change. I'm not 100% sure
> I understand the reason that this is required (I haven't looked at the code),
> but if there is no way to do this without losing the right click behavior,
> we at least need to make it an option (and I'd prefer one defaulting to the
> same as it does currently).
> -- Chris
>> Is this behaviour something we can live with or would it be better to
>> keep the src URL pointing to the original image?
>> Regards, Roald
>> [1] http://trac.openlayers.org/ticket/2318
>> Roald de Wit
>> Software Engineer
>> Commercial Support for Open Source GIS Software
>> http://lisasoft.com/LISAsoft/SupportedProducts/
>> The contents of this email are confidential and may be subject to legal or professional privilege and copyright. No representation is made that this email is free of viruses or other defects. If you have received this communication in error, you may not copy or distribute any part of it or otherwise disclose its contents to anyone. Please advise the sender of your incorrect receipt of this correspondence.
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
More information about the Dev mailing list
