[OpenLayers-Dev] Vector Layers' order with SelectFeature Control
shuball
shubakk at gmail.com
Tue Sep 29 02:52:34 EDT 2009
Hi everyone, I've got a problem i can't fix.
I got a map with several vector layers on it.
What i want is to allow users to reorganize the order of the layers by doing
some drag & drop on a list of the vector layers of my Map.
When i initialize my map, I reorganize the layers changing their z-index and
redraw all my layers.
When doing some drag&drop, i check the order of my list and change the
z-index of the layers.
Up to there, all is fine.
The big problem is that, when i activate (click on) the selectFeature
control, the last layers of the map.layers pop up on front and i can't
reorganize my layers anymore.
Anyway, checking all the layers' z-index i see that they're all correct, i
mean like i declared them.
I don't really know what to do more, and i thought somebody may have the
answer to this problem
Thanks
View this message in context: http://n2.nabble.com/Vector-Layers-order-with-SelectFeature-Control-tp3734187p3734187.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
