[OpenLayers-Dev] 2.9a release?
Marc Jansen jansen at terrestris.de
Wed Apr 28 05:03:50 EDT 2010
Hi devs,
Although I don't have the right to vote on this, I would really
appreciate a point-release 2.9.1 with the mentioned fixes. Maybe we
should wait another week or so to see if other regressions show up.
Regards (and thanks for all the nice work),
Marc
On 28.04.2010 08:57, Andreas Hocevar wrote:
> Hi,
> there is a regression in the 2.9 release:
> On Apr 28, 2010, at 08:35 , OpenLayers wrote:
>> #2596: Rotated graphics are positioned incorrectly when moved or zoom changes
>>   Reporter:  ahocevar      |       Owner:  ahocevar
>>       Type:  bug           |      Status:  new
>>   Priority:  major         |   Milestone:  2.10 Release
>> Component:  Renderer.SVG  |     Version:  2.9
>> Resolution:                |    Keywords:
>>      State:  Commit        |
>> Comment (by bartvde):
>> Andreas, do you think we should create a 2.9.1 release to fix this issue?
>> My initial reaction would be that this warrants a 2.9.1 release. We've
>> never done point fix releases though in the past, so I am not sure what
>> the policy is.
> Replying to [comment:6 bartvde]:
>> Andreas, do you think we should create a 2.9.1 release to fix this issue? My initial reaction would be that this warrants a 2.9.1 release. We've never done point fix releases though in the past, so I am not sure what the policy is.
> I also think that a 2.9.1 (or 2.9a) release would be the right thing to do. In my opinion, the best way to do so would be:
> * create a 2.9a tag
> * replace contents of http://www.openlayers.org/api/2.9 with the 2.9a release (but do not change the path)
> * announce the 2.9a release, pointing out that people using the hosted api do not need to change anything.
> This 2.9a release could also contain the release in the VERSION_NUMBER tag, to fix http://trac.openlayers.org/ticket/2589.
> Regards,
> Andreas.
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev mailing list
