[OpenLayers-Dev] 2.9a release?
christopher.schmidt at nokia.com christopher.schmidt at nokia.com
Wed Apr 28 08:31:23 EDT 2010
I'm down with a small bugfix release. We should treat the changes as pullups to the 2.9 branch, and re-release from there. We should probably also do a slightly broader (user list?) call for feedback on any regressions we might have missed first, probably.
-- Chris
----- Original message -----
> Hi,
> there is a regression in the 2.9 release:
> On Apr 28, 2010, at 08:35 , OpenLayers wrote:
> > #2596: Rotated graphics are positioned incorrectly when moved or zoom
> changes
> >  Reporter:  ahocevar          |            Owner:  ahocevar
> >          Type:  bug                    |          Status:  new
> >  Priority:  major                |    Milestone:  2.10 Release
> > Component:  Renderer.SVG  |        Version:  2.9
> > Resolution:                              |      Keywords:
> >        State:  Commit              |
> > Comment (by bartvde):
> > Andreas, do you think we should create a 2.9.1 release to fix this
> issue?
> > My initial reaction would be that this warrants a 2.9.1 release. We've
> > never done point fix releases though in the past, so I am not sure
> what
> > the policy is.
> Replying to [comment:6 bartvde]:
> issue? My initial reaction would be that this warrants a 2.9.1 release.
> We've never done point fix releases though in the past, so I am not sure
> what the policy is.
> I also think that a 2.9.1 (or 2.9a) release would be the right thing to
> do. In my opinion, the best way to do so would be:
> * create a 2.9a tag
> * replace contents of http://www.openlayers.org/api/2.9 with the 2.9a
> release (but do not change the path)
> * announce the 2.9a release, pointing out that people using the hosted
> api do not need to change anything.
> This 2.9a release could also contain the release in the VERSION_NUMBER
> tag, to fix http://trac.openlayers.org/ticket/2589.
> Regards,
> Andreas.
> Dev mailing list
> Dev at openlayers.org<mailto:Dev at openlayers.org>
> http://openlayers.org/mailman/listinfo/dev
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20100428/071aebda/attachment.html
More information about the Dev mailing list
