[OpenLayers-Dev] 2.9a release?
Bart van den Eijnden
bartvde at osgis.nl
Wed Apr 28 08:58:47 EDT 2010
Hey Chris,
so you are proposing to just pull up this change (and any other regression that might come up in the near future) to the 2.9 branch, and then release as 2.9 again? So just update the builds on openlayers.org and update the download files for 2.9?
Best regards,
Bart
On Apr 28, 2010, at 2:31 PM, <christopher.schmidt at nokia.com> wrote:
> I'm down with a small bugfix release. We should treat the changes as pullups to the 2.9 branch, and re-release from there. We should probably also do a slightly broader (user list?) call for feedback on any regressions we might have missed first, probably.
> -- Chris
> ----- Original message -----
> > Hi,
> > there is a regression in the 2.9 release:
> > On Apr 28, 2010, at 08:35 , OpenLayers wrote:
> > > #2596: Rotated graphics are positioned incorrectly when moved or zoom
> > changes
> > > Reporter: ahocevar | Owner: ahocevar
> > > Type: bug | Status: new
> > > Priority: major | Milestone: 2.10 Release
> > > Component: Renderer.SVG | Version: 2.9
> > > Resolution: | Keywords:
> > > State: Commit |
> > > Comment (by bartvde):
> > > Andreas, do you think we should create a 2.9.1 release to fix this
> > issue?
> > > My initial reaction would be that this warrants a 2.9.1 release. We've
> > > never done point fix releases though in the past, so I am not sure
> > what
> > > the policy is.
> > Replying to [comment:6 bartvde]:
> > issue? My initial reaction would be that this warrants a 2.9.1 release.
> > We've never done point fix releases though in the past, so I am not sure
> > what the policy is.
> > I also think that a 2.9.1 (or 2.9a) release would be the right thing to
> > do. In my opinion, the best way to do so would be:
> > * create a 2.9a tag
> > * replace contents of http://www.openlayers.org/api/2.9 with the 2.9a
> > release (but do not change the path)
> > * announce the 2.9a release, pointing out that people using the hosted
> > api do not need to change anything.
> > This 2.9a release could also contain the release in the VERSION_NUMBER
> > tag, to fix http://trac.openlayers.org/ticket/2589.
> > Regards,
> > Andreas.
> > Dev mailing list
> > Dev at openlayers.org
> > http://openlayers.org/mailman/listinfo/dev
> Dev mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20100428/e85f7538/attachment.html
More information about the Dev
