[OpenLayers-Dev] Projection
Adam Ratcliffe
adam at prema.co.nz
Fri Aug 13 17:21:14 EDT 2010
EPSG:4326 is the code for the WGS84 coordinate reference system. OpenStreetMap tiles are rendered using the Spherical Mercator coordinate reference system (EPSG:900913 )so in order to use longitude/latitude coordinates with a Spherical Mercator map they must first be reprojected to Spherical Mercator coordinates.
There's a good description of this on the OSM website: http://docs.openlayers.org/library/spherical_mercator.html
Cheers
Adam
On 14/08/2010, at 2:44 AM, Leonardo Gaona wrote:
> What are the projections EPSG: 4326 ??
> and why we must transform from EPSG: 4326 to EPSG:900913 when we use osm maps _______________________________________________
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev
