[OpenLayers-Dev] Projection
christopher.schmidt at nokia.com
Fri Aug 13 17:25:14 EDT 2010
On Aug 13, 2010, at 5:21 PM, ext Adam Ratcliffe wrote:
> EPSG:4326 is the code for the WGS84 coordinate reference system. OpenStreetMap tiles are rendered using the Spherical Mercator coordinate reference system (EPSG:900913 )so in order to use longitude/latitude coordinates with a Spherical Mercator map they must first be reprojected to Spherical Mercator coordinates.
> There's a good description of this on the OSM website: http://docs.openlayers.org/library/spherical_mercator.html
(Which is, of course, on the OpenLayers website.)
-- Chris
> Cheers
> Adam
> On 14/08/2010, at 2:44 AM, Leonardo Gaona wrote:
>> What are the projections EPSG: 4326 ??
>> and why we must transform from EPSG: 4326 to EPSG:900913 when we use osm maps _______________________________________________
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
> Dev mailing list
More information about the Dev
