[OpenLayers-Dev] Patrch for getting vector drawing working over
the 180 line going.
Tim Schaub
tschaub at opengeo.org
Wed Aug 18 13:55:48 EDT 2010
On 8/17/10 7:14 PM, Phil Scadden wrote:
>> How do you know that the line (179 0, -179 0) is meant to cross the date line?
> You cant as far as I know. And how would you unambiguously specify it?
Please don't try to bake in any assumptions about heading in a line
segment. Our geometry model is based on coordinates on a plane. My
opinion is that "crossing the dateline" is application logic.
Geometries should be split when the user tries to draw beyond the domain
of the coordinate system.
> We generally store everything in arcSDE in WGS84 lat/long and depend on
> client mapping to sort it out. When you have no unambiguous way of
> specify which way the line goes, the obvious convention is take the
> shortest distance. ship track/air track are overwhelming source of data
> in this catagory while I cant really think of a mapping application
> where you would want 179,0, -179,0 to be circle the globe.
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
More information about the Dev
