[OpenLayers-Dev] [OpenLayers-Users] Help to create FeatureId
filter & OpenLayers.Filter.Logical.NOT
Andreas Hocevar
ahocevar at opengeo.org
Thu Dec 2 06:20:42 EST 2010
It violates the spec, but as you have found out, GeoServer at this point seems to support it. For the record, here is a patch to make it work through OpenLayers:
Index: tests/Format/Filter/v1.html
--- tests/Format/Filter/v1.html (revision 10937)
+++ tests/Format/Filter/v1.html (working copy)
@@ -166,7 +166,41 @@
+ function test_Not_FeatureId(t) {
+ t.plan(3);
+ var str =
+ '<Filter xmlns="http://www.opengis.net/ogc">' +
+ '<Not>' +
+ '<Filter>' +
+ '<FeatureId fid="states.34"/>' +
+ '<FeatureId fid="states.35"/>' +
+ '</Filter>' +
+ '</Not>' +
+ '</Filter>';
+ var format = new OpenLayers.Format.Filter.v1_0_0();
+ var filter = new OpenLayers.Filter.Logical({
+ type: OpenLayers.Filter.Logical.NOT,
+ filters: [new OpenLayers.Filter.FeatureId({
+ fids: ["states.34", "states.35"]
+ // test writing
+ var node = format.write(filter);
+ t.xml_eq(node, str, "filter correctly written");
+ // test reading
+ var doc = (new OpenLayers.Format.XML).read(str);
+ var got = format.read(doc.firstChild);
+ console.log(got);
+ t.eq(got.type, filter.type, "read correct type");
+ t.eq(got.filters[0].fids, filter.filters[0].fids, "read correct fids");
</script>
</head>
<body>
Index: lib/OpenLayers/Format/Filter/v1.js
--- lib/OpenLayers/Format/Filter/v1.js (revision 10937)
+++ lib/OpenLayers/Format/Filter/v1.js (working copy)
@@ -87,9 +87,14 @@
this.readChildNodes(node, obj);
if(obj.fids.length > 0) {
- parent.filter = new OpenLayers.Filter.FeatureId({
+ var filter = new OpenLayers.Filter.FeatureId({
fids: obj.fids
+ if (parent.filters) {
+ parent.filters.push(filter)
+ } else {
+ parent.filter = filter;
} else if(obj.filters.length > 0) {
parent.filter = obj.filters[0];
@@ -390,7 +395,8 @@
* Method: getFilterType
getFilterType: function(filter) {
- var filterType = this.filterMap[filter.type];
+ var filterType = filter instanceof OpenLayers.Filter.FeatureId ?
+ "Filter" : this.filterMap[filter.type];
if(!filterType) {
throw "Filter writing not supported for rule type: " + filter.type;
Regards,
Andreas.
On Dec 13, 2009, at 20:18 , Ivan Grcic wrote:
> From the Filter Impl. Specs:
> The XML encoding for the logical operators AND, OR and NOT is defined
> by the following XML Schema fragment:
> <element name="And" type="ogc:BinaryLogicOpType"
> substitutionGroup="ogc:logicOps"/>
> <element name="Or" type="ogc:BinaryLogicOpType"
> <element name="Not" type="ogc:UnaryLogicOpType"
> <element name="logicOps" type="ogc:LogicOpsType" abstract="true"/>
> <complexType name="LogicOpsType" abstract="true"/>
> <complexType name="BinaryLogicOpType">
> <complexContent>
> <extension base="ogc:LogicOpsType">
> <choice minOccurs="2" maxOccurs="unbounded">
> <element ref="ogc:comparisonOps"/>
> <element ref="ogc:spatialOps"/>
> <element ref="ogc:logicOps"/>
> </choice>
> </extension>
> </complexContent>
> </complexType>
> <complexType name="UnaryLogicOpType">
> <complexContent>
> <sequence>
> <choice>
> </choice>
> </sequence>
> </extension>
> </complexContent>
> </complexType>
> It doesnt have FeatureIdType choice. And putting filter manually into
> geoserver expectedly throws:
> Your .SLD file does not conform to the SLD Schema
> cvc-complex-type.2.4.a: Invalid content starting with element
> 'ogc:FeatureId'. One of '{"http://www.opengis.net/ogc":comparisonOps,
> "http://www.opengis.net/ogc":spatialOps,
> "http://www.opengis.net/ogc":logicOps}' is expected
> But creating filter in OL and making request DOES return all the
> features but listed ones. So geoserver does support it.
> Does anyone know what would be the correct (compliant) way then to
> make filter that will fetch all the features except the ones in
> FeatureIds ?
> Cheers
> On Sun, Dec 13, 2009 at 2:38 PM, Eric Lemoine
> <eric.lemoine at camptocamp.com> wrote:
>> On Thursday, December 10, 2009, Ivan Grcic <ivan.grcic at geofoto.hr> wrote:
>>> Hi devs,
>>> before opening ticket i want to confirm that im right about this issue
>>> Currently its not possible to make filter like this:
>>> <ogc:Filter xmlns:ogc="http://www.opengis.net/ogc">
>>> <And>
>>> <Not><ogc:FeatureId fid="Feature.1"/></Not>
>>> <Not><ogc:FeatureId fid="Feature.2"/></Not>
>>> </And>
>>> </Filter>
>>> I trace the source of it, in Format/Filter/v1.js writers&readers for
>>> AND,OR, NOT do not handle FeatureIds seperatly as root "Filter" does.
>>> line: 296
>>> "Not": function(filter) {
>>> var node = this.createElementNSPlus("ogc:Not");
>>> var childFilter = filter.filters[0];
>>> this.writeNode(
>>> this.getFilterType(childFilter), childFilter, node
>>> return node;
>>> That happens because FeatureId doesnt have type and getFilterType
>>> method throws "Filter writing not supported for rule type: undefined"
>>> if we try to encapsulate FeatureId with Logical.Not
>>> Its neccesary to check if filter is of FeatureId type and treat it
>>> differently, like the root Filter element does
>>> var sub = childFilter.CLASS_NAME.split(".").pop();
>>> if(sub === "FeatureId") {
>>> for(var i=0; i<childFilter.fids.length; ++i) {
>>> this.writeNode("FeatureId", childFilter.fids[i], node);
>>> } else {
>>> this.writeNode(
>>> return node;
>>> Please can anyone confirm this?
>> Hi. I don't know the specs but they allow FeatureID filters within NOT
>> filters then I agree there's a bug in the library. And I think the
>> problem exists for AND and OR as well, no?
>> Cheers,
>> Eric Lemoine
>> Camptocamp France SAS
>> Savoie Technolac, BP 352
>> 73377 Le Bourget du Lac, Cedex
>> Tel : 00 33 4 79 44 44 96
>> Mail : eric.lemoine at camptocamp.com
>> http://www.camptocamp.com
> Ivan Grcic
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
More information about the Dev
