[OpenLayers-Dev] simplifyLineString
Christian Mayer mayer at terrestris.de
Wed Dec 15 06:57:11 EST 2010
Thanks for reviewing Andreas! I attached the new patch to the ticket.
Best regards,
Chris
Am 15.12.2010 10:25, schrieb Andreas Hocevar:
> Hi,
> I just commented on the ticket. If the patch can be changed so this new functionality gets implemented as OpenLayers.Geometry.LineString::simplify, then it will be easier to move this to a separate Geometry library later. When done, I'll give it a final review and make sure that it becomes part of the library.
> Andreas.
> On Dec 15, 2010, at 10:15 , Marc Jansen wrote:
>> Hi list,
>> Is there any news about this ticket? Is it likely that this will make it into trunk? A comment on the ticket would be appreciated, I guess :-)
>> I faintly remember that there were ideas of having/developing a seperate geometry-library that would handle these sorts of functionality -- is there any progress on that library/effort?
>> Best Regards,
>> Marc
>> On 11.10.2010 08:30, Christian Mayer wrote:
>>> Hello list,
>>> I opened an enhancement ticket (http://trac.osgeo.org/openlayers/ticket/2869).
>>> Thanks for any review!
>>> Best regards,
>>> Chris
>>>   Dipl.-Ing.(FH) Christian Mayer
>>>   - Anwendungsentwickler -
>>>   terrestris GmbH&  Co. KG
>>>   Irmintrudisstraße 17
>>>   53111 Bonn
>>>   Tel:    ++49 (0)228 / 96 28 99 -53
>>>   Fax:    ++49 (0)228 / 96 28 99 -57
>>>   Email:
>>>   Web:
>>> http://www.terrestris.de
>>>   Amtsgericht Bonn, HRA 6835
>>>   Komplementärin:  terrestris Verwaltungsgesellschaft mbH
>>>   vertreten durch: Hinrich Paulsen, Till Adams
>>> Am 07.10.2010 12:25, schrieb Christian Mayer:
>>>> Hello list,
>>>> I have written a little patch (see attached file) for OpenLayers.Util in order to provide a function simplifiyng LineStrings. Base of the code is the Douglas-Peucker algorithm. Due to a threshhold unnecessary vertices are removed.
>>>> I would be happy if this could be included to the code base of OpenLayers. Shall I open an enhancement ticket?
>>>> Best regards,
>>>> Chris
>>>> _______________________________________________
>>>> Dev mailing list
>>>> Dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
>>> Dev mailing list
>> Dev mailing list
More information about the Dev mailing list
