[OpenLayers-Dev] simplifyLineString
Andreas Hocevar
ahocevar at opengeo.org
Wed Dec 15 04:25:59 EST 2010
I just commented on the ticket. If the patch can be changed so this new functionality gets implemented as OpenLayers.Geometry.LineString::simplify, then it will be easier to move this to a separate Geometry library later. When done, I'll give it a final review and make sure that it becomes part of the library.
Andreas.
On Dec 15, 2010, at 10:15 , Marc Jansen wrote:
> Hi list,
> Is there any news about this ticket? Is it likely that this will make it into trunk? A comment on the ticket would be appreciated, I guess :-)
> I faintly remember that there were ideas of having/developing a seperate geometry-library that would handle these sorts of functionality -- is there any progress on that library/effort?
> Best Regards,
> Marc
> On 11.10.2010 08:30, Christian Mayer wrote:
>> Hello list,
>> I opened an enhancement ticket (http://trac.osgeo.org/openlayers/ticket/2869).
>> Thanks for any review!
>> Best regards,
>> Chris
>> Dipl.-Ing.(FH) Christian Mayer
>> - Anwendungsentwickler -
>> terrestris GmbH & Co. KG
>> Irmintrudisstraße 17
>> 53111 Bonn
>> Tel: ++49 (0)228 / 96 28 99 -53
>> Fax: ++49 (0)228 / 96 28 99 -57
>> Email:
>> mayer at terrestris.de
>> Web:
>> http://www.terrestris.de
>> Amtsgericht Bonn, HRA 6835
>> Komplementärin: terrestris Verwaltungsgesellschaft mbH
>> vertreten durch: Hinrich Paulsen, Till Adams
>> Am 07.10.2010 12:25, schrieb Christian Mayer:
>>> Hello list,
>>> I have written a little patch (see attached file) for OpenLayers.Util in order to provide a function simplifiyng LineStrings. Base of the code is the Douglas-Peucker algorithm. Due to a threshhold unnecessary vertices are removed.
>>> I would be happy if this could be included to the code base of OpenLayers. Shall I open an enhancement ticket?
>>> Best regards,
>>> Chris
>>> Dev mailing list
>>> Dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
>> Dev mailing list
> Dev mailing list
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
More information about the Dev
