[OpenLayers-Dev] Markers and Vector Layer conflict
Alex G.
unseen.wizard at gmail.com
Thu Feb 4 09:38:14 EST 2010
Alexandre,
thanks for your thoughts. Although if I understand what you're saying and
the example correctly, this will not make the markers to pop up with bubbles
where I can put text.
I am currently placing markers with text on them where if you click on the
marker a little bubble will appear.
Here's another snippet that I forgot to include:
var click = new OpenLayers.Control.Click();
map.addControl(click);
click.activate();
var new2 = new OpenLayers.Layer.Text( 'Texts', { layerToUse:
markers, newLat: '4188741.7304207', newLon: '217101.58694106', newTitle:
"Title1", newDesc: "Desc1", idUser : '62', userName: 'admin', newIcon:
'images/markers/marker.png'} );
new2.parseData();
var new3 = new OpenLayers.Layer.Text( 'Texts', { layerToUse:
markers, newLat: '4182021.7304207', newLon: '210801.58694106', newTitle:
"Title2", newDesc: "Desc2", idUser : '62', userName: 'admin', newIcon:
'images/markers/marker-blue.png'} );
new3.parseData();
var new4 = new OpenLayers.Layer.Text( 'Texts', { layerToUse:
markers, newLat: '4179441.7304207', newLon: '219681.58694106', newTitle:
"Title3", newDesc: "Desc3", idUser : '62', userName: 'admin', newIcon:
new4.parseData();
I am not quite sure what that click function does, could it be the culprit?
I have used this example as a base:
http://dev.openlayers.org/releases/OpenLayers-2.8/examples/markers.html
The thing is I use a form also to create new bubbles where users can enter a
title, marker icon and description and get a result similar to the above.
Thanks again,
Alex
On Thu, Feb 4, 2010 at 3:34 PM, Alexandre Dube <adube at mapgears.com> wrote:
> Alex,
> I just looked at the SelectFeature control code and I think you could try
> this solution :
> Change you Marker layer for a Vector one (you can define externalGraphic
> to a vector feature, see an example [1]) and then configure your
> SelectFeature control with both your layers :
> var select = new OpenLayers.Control.SelectFeature([vectors, markers],
> options);
> The SelectFeature control will create a RootContainer layer object
> enabling selection on both at the same time, thus fixing your issue.
> Please, tell me if that worked.
> Hope this helps,
> Alexandre
> [1] http://openlayers.org/dev/examples/styles-unique.html
> Alex G. wrote:
>> Hi all,
>> I am probably having a conflict problem with some of my layers. I
>> currently have 3 layers active on my installation:
>> - a layer containing the data from a shapefile (running WMS)
>> - a vector layer where users can draw
>> - a layer dedicated to markers.
>> I have noticed that if I place a marker, I cannot interact with it
>> afterwards unless I hide the vectors layer. The order is correct, I load
>> first the shp layer, then the vector one and then the markers one.
>> I include here some of my code in hope that it will help, it's mostly from
>> examples on openlayers so there's really nothing new.
>> map = new OpenLayers.Map('map',{maxExtent: new
>> OpenLayers.Bounds(195441.084706006,4171163.51662705,240142.089176109,4203199.94421431),
>> maxResolution: 120, units: 'dd'});
>> layer = new OpenLayers.Layer.WMS( 'Landmass ', '
>> http://localhost:8585/cgi-bin/mapserv?map=/opt/fgs/apps/gmap-demo-cvs_MS_VERSION_54/htdocs/gmap75a.map&<
>> http://localhost:8585/cgi-bin/mapserv?map=/opt/fgs/apps/gmap-demo-cvs_MS_VERSION_54/htdocs/gmap75a.map&>',
>> layers: 'zak',
>> format:'PNG',
>> bbox:
>> '195441.084706006,4171163.51662705,240142.089176109,4203199.94421431',
>> srs: 'EPSG:4326'
>> lakegr_wms = new OpenLayers.Layer.WMS( 'Lakes',
>> layers: 'sedi',
>> transparent: 'true',
>> format: 'image/png'
>> {isBaseLayer: false}
>> vectors = new OpenLayers.Layer.Vector( 'Editable' );
>> vectors.onFeatureInsert=function(feature) {
>> var wkt=wktwriter.write(feature);
>> console.log(wkt);
>> map.addLayer(layer);
>> map.addLayers([lakegr_wms,vectors]);
>> map.addControl(new OpenLayers.Control.LayerSwitcher());
>> controls = {
>> point: new OpenLayers.Control.DrawFeature(vectors,
>> OpenLayers.Handler.Point),
>> line: new OpenLayers.Control.DrawFeature(vectors,
>> OpenLayers.Handler.Path),
>> polygon: new OpenLayers.Control.DrawFeature(vectors,
>> OpenLayers.Handler.Polygon),
>> drag: new OpenLayers.Control.DragFeature(vectors)
>> for(var key in controls) {
>> map.addControl(controls[key]);
>> map.zoomTo(1);
>> var options = {
>> hover: true,
>> highlightOnly: true
>> var select = new
>> OpenLayers.Control.SelectFeature(vectors, options);
>> selectCtrl = new OpenLayers.Control.SelectFeature(vectors,
>> clickout: true,
>> onSelect: serialize
>> map.addControl(select);
>> map.addControl(selectCtrl);
>> select.activate();
>> selectCtrl.activate();
>> * Inherits from:
>> var markers = new OpenLayers.Layer.Markers( 'Markers' );
>> map.addLayer(markers);
>> Rest of the code is taken from the markers example on OpenLayers.
>> Can anyone think of any reason why they would conflict? I am thinking it
>> has something to do with clicks and some of the controls I use might be
>> conflicting although I can't see any Javascript errors.
>> Thanks in advance.
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
> Alexandre Dubé
> Mapgears
> www.mapgears.com
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20100204/aeeb79a4/attachment.html
More information about the Dev
