[OpenLayers-Dev] Markers and Vector Layer conflict
Alexandre Dube
adube at mapgears.com
Thu Feb 4 13:26:41 EST 2010
Alex,
Take a look at this example [1]. Vector features can be used with a
SelectFeature control to open popups. You only need to define the
externalGraphic to have images and define the geometry type to "point".
See an other example of "draw" types.
You might be interested to take a look at this example [3] too (it's a
development sandbox for a RedLining widget in GeoExt). It uses a lot of
OpenLayers components to draw/select the features. Maybe that can helps
too.
Kind regards,
Alexandre
[1] http://openlayers.org/dev/examples/select-feature-openpopup.html
[2] http://openlayers.org/dev/examples/draw-feature.html
[3]
http://dev.geoext.org/sandbox/redlining/ux/FeatureEditing/examples/ControlerOnlyExample.html
Alex G. wrote:
> Alexandre,
> thanks for your thoughts. Although if I understand what you're saying
> and the example correctly, this will not make the markers to pop up
> with bubbles where I can put text.
> I am currently placing markers with text on them where if you click on
> the marker a little bubble will appear.
> Here's another snippet that I forgot to include:
> var click = new OpenLayers.Control.Click();
> map.addControl(click);
> click.activate();
> var new2 = new OpenLayers.Layer.Text( 'Texts', { layerToUse:
> markers, newLat: '4188741.7304207', newLon: '217101.58694106',
> newTitle: "Title1", newDesc: "Desc1", idUser : '62', userName:
> 'admin', newIcon: 'images/markers/marker.png'} );
> new2.parseData();
> var new3 = new OpenLayers.Layer.Text( 'Texts', { layerToUse:
> markers, newLat: '4182021.7304207', newLon: '210801.58694106',
> newTitle: "Title2", newDesc: "Desc2", idUser : '62', userName:
> 'admin', newIcon: 'images/markers/marker-blue.png'} );
> new3.parseData();
> var new4 = new OpenLayers.Layer.Text( 'Texts', { layerToUse:
> markers, newLat: '4179441.7304207', newLon: '219681.58694106',
> newTitle: "Title3", newDesc: "Desc3", idUser : '62', userName:
> new4.parseData();
> I am not quite sure what that click function does, could it be the
> culprit?
> I have used this example as a base:
> http://dev.openlayers.org/releases/OpenLayers-2.8/examples/markers.html
> The thing is I use a form also to create new bubbles where users can
> enter a title, marker icon and description and get a result similar to
> the above.
> Thanks again,
> Alex
> On Thu, Feb 4, 2010 at 3:34 PM, Alexandre Dube <adube at mapgears.com
> <mailto:adube at mapgears.com>> wrote:
> Alex,
> I just looked at the SelectFeature control code and I think you
> could try this solution :
> Change you Marker layer for a Vector one (you can define
> externalGraphic to a vector feature, see an example [1]) and then
> configure your SelectFeature control with both your layers :
> var select = new OpenLayers.Control.SelectFeature([vectors,
> markers], options);
> The SelectFeature control will create a RootContainer layer
> object enabling selection on both at the same time, thus fixing
> your issue. Please, tell me if that worked.
> Hope this helps,
> Alexandre
> [1] http://openlayers.org/dev/examples/styles-unique.html
> Alex G. wrote:
> Hi all,
> I am probably having a conflict problem with some of my
> layers. I currently have 3 layers active on my installation:
> - a layer containing the data from a shapefile (running WMS)
> - a vector layer where users can draw
> - a layer dedicated to markers.
> I have noticed that if I place a marker, I cannot interact
> with it afterwards unless I hide the vectors layer. The order
> is correct, I load first the shp layer, then the vector one
> and then the markers one.
> I include here some of my code in hope that it will help, it's
> mostly from examples on openlayers so there's really nothing new.
> map = new OpenLayers.Map('map',{maxExtent: new
> OpenLayers.Bounds(195441.084706006,4171163.51662705,240142.089176109,4203199.94421431),
> maxResolution: 120, units: 'dd'});
> layer = new OpenLayers.Layer.WMS( 'Landmass ',
> 'http://localhost:8585/cgi-bin/mapserv?map=/opt/fgs/apps/gmap-demo-cvs_MS_VERSION_54/htdocs/gmap75a.map&
> <http://localhost:8585/cgi-bin/mapserv?map=/opt/fgs/apps/gmap-demo-cvs_MS_VERSION_54/htdocs/gmap75a.map&>
> <http://localhost:8585/cgi-bin/mapserv?map=/opt/fgs/apps/gmap-demo-cvs_MS_VERSION_54/htdocs/gmap75a.map&>>',
> layers: 'zak',
> format:'PNG',
> bbox:
> '195441.084706006,4171163.51662705,240142.089176109,4203199.94421431',
> srs: 'EPSG:4326'
> lakegr_wms = new OpenLayers.Layer.WMS( 'Lakes',
> layers: 'sedi',
> transparent: 'true',
> format: 'image/png'
> {isBaseLayer: false}
> vectors = new OpenLayers.Layer.Vector( 'Editable' );
> vectors.onFeatureInsert=function(feature) {
> var wkt=wktwriter.write(feature);
> console.log(wkt);
> map.addLayer(layer);
> map.addLayers([lakegr_wms,vectors]);
> map.addControl(new OpenLayers.Control.LayerSwitcher());
> controls = {
> point: new
> OpenLayers.Control.DrawFeature(vectors,
> OpenLayers.Handler.Point),
> line: new
> OpenLayers.Handler.Path),
> polygon: new
> OpenLayers.Handler.Polygon),
> drag: new
> OpenLayers.Control.DragFeature(vectors)
> for(var key in controls) {
> map.addControl(controls[key]);
> map.zoomTo(1);
> var options = {
> hover: true,
> highlightOnly: true
> var select = new
> OpenLayers.Control.SelectFeature(vectors, options);
> selectCtrl = new
> clickout: true,
> onSelect: serialize
> map.addControl(select);
> map.addControl(selectCtrl);
> select.activate();
> selectCtrl.activate();
> * Inherits from:
> var markers = new OpenLayers.Layer.Markers(
> 'Markers' );
> map.addLayer(markers);
> Rest of the code is taken from the markers example on OpenLayers.
> Can anyone think of any reason why they would conflict? I am
> thinking it has something to do with clicks and some of the
> controls I use might be conflicting although I can't see any
> Javascript errors.
> Thanks in advance.
> Dev mailing list
> Dev at openlayers.org <mailto:Dev at openlayers.org>
> http://openlayers.org/mailman/listinfo/dev
> Alexandre Dubé
> Mapgears
> www.mapgears.com <http://www.mapgears.com>
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Dev
