[OpenLayers-Dev] GetFeature control question
Andreas Hocevar ahocevar at opengeo.org
Sat Feb 6 13:21:45 EST 2010
Eric Lemoine wrote:
> On Mon, Jan 11, 2010 at 3:22 PM, Bart van den Eijnden <bartvde at osgis.nl> wrote:
>> Hi list,
>> I am failing to understand the following line in OpenLayers.Control.GetFeature:
>> maxFeatures: options.single == true ? this.maxFeatures : undefined,
>> I would expect it to be:
>> maxFeatures: options.single == true ? 1: this.maxFeatures,
>> so if we only want a single feature, have it set to 1, otherwise use the maxFeatures given by the application designer.
> I'd make more sense to me too.
You are looking at this line without the context. There is also:
if(options.single == true) {
    this.selectBestFeature(result.features,
    bounds.getCenterLonLat(), options);
} else {
    this.select(result.features);
One of the key advantages of the GetFeature control over WMSGetFeature
is that it will *always* just return *one single feature* on a click,
and this feature will be the *best matching one*. The maxFeatures config
option is just about how many features to use to determine the best
matching one. Maybe this should be documented better.
Regards,
Andreas.
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
More information about the Dev mailing list
