[OpenLayers-Dev] GetFeature control question
bartvde at osgis.nl
bartvde at osgis.nl
Sat Feb 6 13:48:41 EST 2010
Andreas,
but why do you not leave the best match up to the WFS by specifying
maxFeatures 1? What is the purpose/advantage of doing this client-side?
Best regards,
Bart
> Eric Lemoine wrote:
>> On Mon, Jan 11, 2010 at 3:22 PM, Bart van den Eijnden <bartvde at osgis.nl>
>> wrote:
>>> Hi list,
>>> I am failing to understand the following line in
>>> OpenLayers.Control.GetFeature:
>>> maxFeatures: options.single == true ? this.maxFeatures : undefined,
>>> I would expect it to be:
>>> maxFeatures: options.single == true ? 1: this.maxFeatures,
>>> so if we only want a single feature, have it set to 1, otherwise use
>>> the maxFeatures given by the application designer.
>> I'd make more sense to me too.
> You are looking at this line without the context. There is also:
> if(options.single == true) {
> this.selectBestFeature(result.features,
> bounds.getCenterLonLat(), options);
> } else {
> this.select(result.features);
> One of the key advantages of the GetFeature control over WMSGetFeature
> is that it will *always* just return *one single feature* on a click,
> and this feature will be the *best matching one*. The maxFeatures config
> option is just about how many features to use to determine the best
> matching one. Maybe this should be documented better.
> Regards,
> Andreas.
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
More information about the Dev
