[OpenLayers-Dev] GetFeature control question
Andreas Hocevar
ahocevar at opengeo.org
Sat Feb 6 14:55:52 EST 2010
bartvde at osgis.nl wrote:
> Andreas,
> but why do you not leave the best match up to the WFS by specifying
> maxFeatures 1? What is the purpose/advantage of doing this client-side?
Where does the WFS spec say that setting maxFeatures to 1 will return
the best matching feature? Usually that returns the first one matching
the filter condition.
Regards,
Andreas.
> Best regards,
> Bart
>> Eric Lemoine wrote:
>>> On Mon, Jan 11, 2010 at 3:22 PM, Bart van den Eijnden <bartvde at osgis.nl>
>>> wrote:
>>>> Hi list,
>>>> I am failing to understand the following line in
>>>> OpenLayers.Control.GetFeature:
>>>> maxFeatures: options.single == true ? this.maxFeatures : undefined,
>>>> I would expect it to be:
>>>> maxFeatures: options.single == true ? 1: this.maxFeatures,
>>>> so if we only want a single feature, have it set to 1, otherwise use
>>>> the maxFeatures given by the application designer.
>>> I'd make more sense to me too.
>> You are looking at this line without the context. There is also:
>> if(options.single == true) {
>> this.selectBestFeature(result.features,
>> bounds.getCenterLonLat(), options);
>> } else {
>> this.select(result.features);
>> One of the key advantages of the GetFeature control over WMSGetFeature
>> is that it will *always* just return *one single feature* on a click,
>> and this feature will be the *best matching one*. The maxFeatures config
>> option is just about how many features to use to determine the best
>> matching one. Maybe this should be documented better.
>> Regards,
>> Andreas.
>> Andreas Hocevar
>> OpenGeo - http://opengeo.org/
>> Expert service straight from the developers.
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Andreas Hocevar
More information about the Dev
