[OpenLayers-Dev] GetFeature control question
Bart van den Eijnden
bartvde at osgis.nl
Sun Feb 7 04:14:25 EST 2010
I think I am missing this up with WMS GetFeatureInfo, where the server does have to do a best match.
Sorry for the noise.
Best regards,
Bart
On Feb 6, 2010, at 8:55 PM, Andreas Hocevar wrote:
> bartvde at osgis.nl wrote:
>> Andreas,
>> but why do you not leave the best match up to the WFS by specifying
>> maxFeatures 1? What is the purpose/advantage of doing this client-side?
> Where does the WFS spec say that setting maxFeatures to 1 will return the best matching feature? Usually that returns the first one matching the filter condition.
> Regards,
> Andreas.
>> Best regards,
>> Bart
>>> Eric Lemoine wrote:
>>>> On Mon, Jan 11, 2010 at 3:22 PM, Bart van den Eijnden <bartvde at osgis.nl>
>>>> wrote:
>>>>> Hi list,
>>>>> I am failing to understand the following line in
>>>>> OpenLayers.Control.GetFeature:
>>>>> maxFeatures: options.single == true ? this.maxFeatures : undefined,
>>>>> I would expect it to be:
>>>>> maxFeatures: options.single == true ? 1: this.maxFeatures,
>>>>> so if we only want a single feature, have it set to 1, otherwise use
>>>>> the maxFeatures given by the application designer.
>>>> I'd make more sense to me too.
>>> You are looking at this line without the context. There is also:
>>> if(options.single == true) {
>>> this.selectBestFeature(result.features,
>>> bounds.getCenterLonLat(), options);
>>> } else {
>>> this.select(result.features);
>>> One of the key advantages of the GetFeature control over WMSGetFeature
>>> is that it will *always* just return *one single feature* on a click,
>>> and this feature will be the *best matching one*. The maxFeatures config
>>> option is just about how many features to use to determine the best
>>> matching one. Maybe this should be documented better.
>>> Regards,
>>> Andreas.
>>> Andreas Hocevar
>>> OpenGeo - http://opengeo.org/
>>> Expert service straight from the developers.
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
> Andreas Hocevar
More information about the Dev
