[OpenLayers-Dev] Add info in XML Transaction
Christopher Schmidt
crschmidt at metacarta.com
Tue Feb 16 07:53:40 EST 2010
On Tue, Feb 16, 2010 at 02:22:46AM -0800, jessisena wrote:
> Hi,
> I'd like to add some info to the XML created as a request when you DELETE a
> feature, and you save this. I've tried to add options to my saveStrategy
> variable as the following way:
> var saveStrategy = new OpenLayers.Strategy.Save({options: currentInfo});
> but it doesn't work.
So you're saying that:
saveStrategy.options == currentInfo
is not treu after this? It looks like it should be, and is in my tests.
-- Chris
> Is there any way to do it? And how?
> Thanks,
> View this message in context: http://n2.nabble.com/Add-info-in-XML-Transaction-tp4579523p4579523.html
> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Christopher Schmidt
MetaCarta
More information about the Dev
