[OpenLayers-Dev] Add info in XML Transaction
jessisena
jessica.sena at scpec.net
Wed Feb 17 03:17:40 EST 2010
B
ut when you do that, in the XML request (with the Delete transaction) this
curentinfo appears? Do you understand what I mean? Because if I do the same
that you say, I cannot achieve it.
Any solution? maybe there's another way to add the info...
Thanks,
View this message in context: http://n2.nabble.com/Add-info-in-XML-Transaction-tp4579523p4584886.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
