[OpenLayers-Dev] click + box handler in IE8
Bart van den Eijnden
bartvde at osgis.nl
Wed Feb 17 09:44:25 EST 2010
Okay, this was fixed already in OL trunk in the GetFeature control (I was using 2.8) by having the case handled where bounds is not an OpenLayers.Bounds object.
selectBox: function(position) {
var bounds;
if (position instanceof OpenLayers.Bounds) {
var minXY = this.map.getLonLatFromPixel(
new OpenLayers.Pixel(position.left, position.bottom)
var maxXY = this.map.getLonLatFromPixel(
new OpenLayers.Pixel(position.right, position.top)
bounds = new OpenLayers.Bounds(
minXY.lon, minXY.lat, maxXY.lon, maxXY.lat
} else {
bounds = this.pixelToBounds(position);
Best regards,
Bart
On Feb 17, 2010, at 3:26 PM, Bart van den Eijnden wrote:
> Hi list,
> I am tracking down a problem where a control has a click as well as a box handler, and in IE8 when doing a click the box handler is executed instead of the click handler.
> In IE6 and Firefox all works fine.
> Any ideas/pointers?
> TIA.
> Best regards,
> Bart
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev
