[OpenLayers-Dev] Format GML 3 issue?
Julien Jeudy
julien.jeudy at magellium.fr
Mon Jan 4 07:32:21 EST 2010
Hi Bart,
Thanks you for your answer. I will do this (after submitting a license
agreement).
Best Regards,
Julien
-----Message d'origine-----
De : Bart van den Eijnden [mailto:bartvde at osgis.nl]
Envoyé : lundi 4 janvier 2010 10:03
À : Julien Jeudy
Cc : dev at openlayers.org
Objet : Re: [OpenLayers-Dev] Format GML 3 issue?
Hi Julien,
I think your analysis is correct, so please file a ticket with your proposed
patch. TIA.
Best regards,
Bart
On Jan 4, 2010, at 9:51 AM, Julien Jeudy wrote:
> Dear all,
> I have a doubt on a GML 3 OpenLayers format issue (from a WFS 1.1.0).
> In GML there are two ways to list polygons points:
> 1. a unique posList element: the following geom is correctly transform
from
> GML3 to OpenLayers geometry
<gml:surfaceMember><gml:Polygon><gml:exterior><gml:LinearRing><gml:posList>-
> 8427711.443672495 4658480.583807316 -8428116.646618983 4671596.358484082
> -8429661.427192722 4697373.995504196 -8432776.70314257 .
> 2. a list of pos elements: But this geom is not correctly transform
> <gml:Surface
srsName="EPSG:900913"><gml:patches><gml:PolygonPatch><gml:exterior><gml:Line
> arRing srsName="EPSG:900913">
> <gml:pos>3944245.09999984 3978948.409156078</gml:pos>
> <gml:pos>3944282.8999998407 3978974.7107042107</gml:pos> .
> I think it's due to this part of code (from trunk -
> OpenLayers.Format.GML.v3.js). Because on each iteration of gml pos the
> points array is erased.
> "pos": function(node, obj) {
> var str = this.getChildValue(node).replace(
> this.regExes.trimSpace, ""
> var coords = str.split(this.regExes.splitSpace);
> var point;
> if(this.xy) {
> point = new OpenLayers.Geometry.Point(
> coords[0], coords[1], coords[2]
> } else {
> coords[1], coords[0], coords[2]
> obj.points = [point];
> Does anyone know whether the GML is not conform or if it's possible to
> propose a patch?
> If it's not a GML conformity issue, I think that the following patch can
> solve the problem but I'm not sure it's the best way:
> if(obj.points) {
> obj.points.push(point);
> } else {
> thanks,
> Julien
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev
