[OpenLayers-Dev] Failing test "BaseTypes/Element.html" on FF
3.5.6 (Ubuntu 09.10)
Andreas Hocevar
ahocevar at opengeo.org
Wed Jan 6 11:48:37 EST 2010
On 2010-01-06 16:44, Marc Jansen wrote:
> Hi Andreas,
> OK, thanks a lot! Maybe the text of the failing test could contain a
> hint to that possible source of error?
I am afraid not, because it is not a failing test you see, but an exception.
But I just made the timeout longer, so it should now also pass on slower
machines. See http://trac.openlayers.org/changeset/9934.
Regards,
Andreas.
> Regards,
> Marc
> Andreas Hocevar wrote:
>> Hi,
>> this is an issue on machines that are too slow, or Firefox instances
>> that use dom processing extensions (like e.g. AdBlock plus) that make
>> the rendering slow.
>> Try to disable such extensions, or renice your browser to e.g. -15 when
>> running tests.
>> There is nothing wrong with the code, it is just that delayed tasks may
>> fail when the test is running too slow.
>> Regards,
>> Andreas.
>> On 2010-01-06 10:36, Marc Jansen wrote:
>>> Hi devs,
>>> I have a failing test "BaseTypes/Element.html" on current trunk:
>>> test_Element_getDimensions planned 4 assertions but got 0; fail
>>> 0 ok 0
>>> exception: in delay_call: object: element is null
>>> in ( null) at
>>> http://localhost/aptana-workspace/OpenLayers/lib/OpenLayers/BaseTypes/Element.js
>>> line 107
>>> in ( ) at
>>> http://localhost/aptana-workspace/OpenLayers/tests/BaseTypes/Element.html
>>> line 126
>>> in ( [object Object],1558) at
>>> http://localhost/aptana-workspace/OpenLayers/tests/run-tests.html
>>> line 1104
>>> in ( 1424) at
>>> line 1015
>>> I am not sure about how to deal with this. I ran the suite on FF
>>> 3.5.6 (Ubuntu 09.10).
>>> Regards,
>>> Marc
>>> Dev mailing list
>>> Dev at openlayers.org
>>> http://openlayers.org/mailman/listinfo/dev
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
More information about the Dev
