[OpenLayers-Dev] Failing test "BaseTypes/Element.html" on FF 3.5.6 (Ubuntu 09.10)
Marc Jansen jansen at terrestris.de
Wed Jan 6 10:44:31 EST 2010
Hi Andreas,
OK, thanks a lot! Maybe the text of the failing test could contain a
hint to that possible source of error?
Regards,
Marc
Andreas Hocevar wrote:
> Hi,
> this is an issue on machines that are too slow, or Firefox instances
> that use dom processing extensions (like e.g. AdBlock plus) that make
> the rendering slow.
> Try to disable such extensions, or renice your browser to e.g. -15 when
> running tests.
> There is nothing wrong with the code, it is just that delayed tasks may
> fail when the test is running too slow.
> Regards,
> Andreas.
> On 2010-01-06 10:36, Marc Jansen wrote:
>> Hi devs,
>> I have a failing test "BaseTypes/Element.html" on current trunk:
>>     test_Element_getDimensions planned 4 assertions but got 0; fail 0 ok 0
>>     exception: in delay_call: object: element is null
>>     in ( null) at
>>     http://localhost/aptana-workspace/OpenLayers/lib/OpenLayers/BaseTypes/Element.js
>>     line 107
>>     in ( ) at
>>     http://localhost/aptana-workspace/OpenLayers/tests/BaseTypes/Element.html
>>     line 126
>>     in ( [object Object],1558) at
>>     http://localhost/aptana-workspace/OpenLayers/tests/run-tests.html
>>     line 1104
>>     in ( 1424) at
>>     line 1015
>> I am not sure about how to deal with this. I ran the suite on FF 3.5.6
>> (Ubuntu 09.10).
>> Regards,
>> Marc
>> Dev mailing list
>> Dev at openlayers.org
>> http://openlayers.org/mailman/listinfo/dev
  Dipl.-Geogr. Marc Jansen
  - Anwendungsentwickler -
  terrestris GmbH & Co. KG
  Irmintrudisstraße 17
  53111 Bonn
  Tel:    ++49 (0)228 / 96 28 99 -53
  Fax:    ++49 (0)228 / 96 28 99 -57
  Email:  jansen at terrestris.de
  Web:    http://www.terrestris.de
  Amtsgericht Bonn, HRA 6835
  Komplementärin:  terrestris Verwaltungsgesellschaft mbH
  vertreten durch: Hinrich Paulsen, Till Adams
More information about the Dev mailing list
