[OpenLayers-Dev] problem with vector Layer Feature's geometry, that is null !
Alexandre Dubé adube at mapgears.com
Thu Jan 28 08:38:04 EST 2010
Rohala,
  If you look at the Console tag, you can see the request sent.  From there,
look a the response received.  Does the response have geometry ?  If it
does, put a breakpoint on your format "read" method to see what happens and
why the geometry isn't parsed.
Regards,
Alexandre
View this message in context: http://n2.nabble.com/problem-with-vector-Layer-Feature-s-geometry-that-is-null-tp4472008p4473270.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
