[OpenLayers-Dev] problem with vector Layer Feature's geometry, that is null !
Alexandre Dube adube at mapgears.com
Thu Jan 28 08:44:05 EST 2010
Rohala,
I replied to your message from Nabble because I didn't see it in my
OpenLayers-Dev Mailing-List mailbox. I guess it's because of the big
image attached to it. I'll copy it here for convenience. See below.
BTW, your problem is more suitable for the users mailing list.
Regards,
Alexandre
Alexandre Dubé wrote:
> Rohala,
>   If you look at the Console tag, you can see the request sent.  From there,
> look a the response received.  Does the response have geometry ?  If it
> does, put a breakpoint on your format "read" method to see what happens and
> why the geometry isn't parsed.
> Regards,
> Alexandre
Original message :
HHi guys
I use OpenLayers.Protocol.WFS approach for display a vector layer. this
layer include points.
This is my code :
var saveStrategy = new OpenLayers.Strategy.Save();
EducationLayer = new OpenLayers.Layer.Vector("EducationLayer Ho ha ha", {
strategies: [new OpenLayers.Strategy.BBOX(), saveStrategy],
projection: new OpenLayers.Projection("EPSG:4326"),
styleMap: EduStyles,
protocol: new OpenLayers.Protocol.WFS({
version: "1.1.0",
srsName: "EPSG:4326",
url: "../../cgi-bin/mapserv.exe?map=../../apps/mashar/mashar.map&",
featureNS : "http://localhost:3000/mashar/wfs",
featureType: "Education",
featurePrefix: "MF",
schema:
"http://localhost:3000/cgi-bin/mapserv.exe?map=../../apps/mashar/mashar.map&SERVICE=WFS&version=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=MF:Education
<http://localhost:3000/cgi-bin/mapserv.exe?map=../../apps/mashar/mashar.map&SERVICE=WFS&version=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=MF:Education>"
with this code i can see EducationLayer features retrieved to browser
and loaded (I use Firefox with Firebug extension). but nothing displayed
on map.
When i want to see geometry property of EducationLayer such as
EducationLayer.Features[each number of array].geometry it retrieve null.
where is my wrong?
below picture explain more detail: [1]
I use Mapserver as WFS server with this configs in web section:
WEB
IMAGEPATH "./tmp/"
IMAGEURL "./tmp/"
METADATA
"wfs_title" "Mashar WFS Server"
"wfs_onlineresource"
<http://localhost:3000/cgi-bin/mapserv.exe?map=../../apps/mashar/mashar.map&>"
"wfs_srs" "EPSG:4326"
"wfs_abstract" "Some text"
"wfs_encoding" "UTF-8"
"wfs_namespace_uri" "http://localhost:3000/mashar/wfs"
"wfs_namespace_prefix" "MF"
END
END
And there is Layer definition section in map file:
LAYER
NAME "Education"
TYPE POINT
DATA "Education"
METADATA
"wfs_title" "Education"
"WFS_ABSTRACT" "Education WFS Layer"
"gml_include_items" "all"
END
STATUS DEFAULT
TRANSPARENCY 100
DUMP TRUE
CLASS
NAME 'Education'
STYLE
SYMBOL 'CIRCLE'
SIZE 2
OUTLINECOLOR 0 0 0
COLOR 45 220 182
END
END
END
This problem confused me very much. solving this problem is very
important for me.
Thanks in advance!
[1] http://n2.nabble.com/file/n4472008/error.gif
Alexandre Dubé
Mapgears
www.mapgears.com
More information about the Dev mailing list
