[OpenLayers-Dev] LineString Intersects method
Gagan Bansal
gaganbansal123 at gmail.com
Thu Jul 1 00:52:47 EDT 2010
I am trying to check if the line and point intersects using :
OpenLayers.Geometry.LineString.intersects(). Many times it returns false,
even if line and point intersects.
I am using OpenLayers-2.9.1.
Here is the test case:
Line - "LINESTRING(-120.5859375 33.2666015625,-119.3994140625
34.4970703125,-114.85107421875 35.31005859375,-112.587890625 33.3984375)"
Point - "POINT(-118.67393030208639 34.62674615373335)"
If I calculate the distance between these two, Line and Point using
distanceTo(), the distance is 0 as well as source point and target point
coordinates are same.
Please check where I am doing wrong or is this a bug.
Regards,
Gagan
View this message in context: http://osgeo-org.1803224.n2.nabble.com/LineString-Intersects-method-tp5241986p5241986.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
