[OpenLayers-Dev] Using xy: false with Protocol.WFS
Tim Schaub
tschaub at opengeo.org
Fri Jul 2 12:17:38 EDT 2010
On 7/2/10 3:59 AM, Steven Ottens wrote:
> Sorry for replying on my own mail again, but I discovered I was wrong
> and there is already a very easy way to do this and I want to make
> sure it is archived instead of the approach below:
> use formatOptions: {xy, false} and it's passed on to the Format
> handler (duh!)
Thanks for documenting your experience here. If you're feeling up to it
and have simple example, it would be great to have an addition to the
examples directory.
Tim
> Cheers, Steven
> On Jul 2, 2010, at 11:17 AM, Steven Ottens wrote:
>> Hi all,
>> I've been doing some thinking about this and I believe there's an
>> omission in OpenLayers. Currently there is no way to set the xy to
>> false when using the WFS protocol, even though OpenLayers supports
>> it in the WFST and GML formats. A very simple solution is to add an
>> xy attribute to Protocol/WFS/v1.js and pass it on along with the
>> other options to WFST.
>> Does this make sense? Should I file a ticket with patch and test?
>> Steven
>> On Jun 30, 2010, at 5:30 PM, Steven Ottens wrote:
>>> Hi All,
>>> I'm trying to swap the x and y of coordinates for one specific
>>> WFS layer. The layer is defined as: skGN : new
>>> OpenLayers.Layer.Vector("Norway GN", { strategies: [new
>>> OpenLayers.Strategy.BBOX({resFactor: 1})], visibility: true,
>>> styleMap: GeoViewer.Styles.pointStyles, projection: new
>>> OpenLayers.Projection("EPSG:4258"), protocol: new
>>> OpenLayers.Protocol.WFS({ version: "1.1.0", outputFormat:
>>> "text/xml; subtype=gml/3.2.1", srsName: "EPSG:4258",
>>> extractAttributes:true, url: GeoViewer.Catalog.urls.SK_WFS,
>>> featurePrefix: "gn", featureType: "NamedPlace", featureNS:
>>> "urn:x-inspire:specification:gmlas:GeographicalNames:3.0",
>>> geometryName: "geometry", maxFeatures: "50", schema:
>>> "http://esdin.geodan.nl/fgi/SK/deegree2-wfs/services?service=WFS&version=1.1.0&request=DescribeFeatureType&typeName=GN:NamedPlace&namespace=xmlns=(GN=urn:x-inspire:specification:gmlas:GeographicalNames:3.0)"
>>> I noticed that xy is a parameter of Format.WFST.v1and changing
>>> xy: true to xy: false in code does what I want. However, it does
>>> that for all layers and that's not what I want. Is it possible to
>>> configure one layer to swap xy, using the approach above? I tried
>>> to add xy: false after visibility: true and in the protocol
>>> definition (which obviously doesn't work). Is there a way to send
>>> attributes to the correct Format class?
>>> Regards, Steven _______________________________________________
>>> Dev mailing list Dev at openlayers.org
>>> http://openlayers.org/mailman/listinfo/dev
> _______________________________________________ Dev mailing list
> Dev at openlayers.org http://openlayers.org/mailman/listinfo/dev
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
More information about the Dev
