[OpenLayers-Dev] PanZoomBar doesn't handle forceFixedZoomLevel
correct
Marc Jansen
jansen at terrestris.de
Wed Jul 7 10:47:28 EDT 2010
Hi Fabian,
thanks for the catch and the patch.
It was me that provided the forceFixedZoomLevel-patch in the first place
(see http://trac.openlayers.org/ticket/2288) and it was (at least by me)
never intended to show the behaviour you describe. Could you please add
tests to your ticket (http://trac.openlayers.org/ticket/2725) that fail
without your patch and pass with your patch applied?
Thanks in advance and best regards,
Marc
PS: I am pretty sure you should leave the "Assigned to:" field in the
trac empty so that a core developer can review (and eventually commit)
your changes.
M.
Am 06.07.2010 11:01, schrieb Fabian Patzke (OL):
> Hi I have created a ticket concerning a bug in the PanZoomBar control that is
> active when forceFixedZoomLevel is set to true.
> Ticket: http://trac.openlayers.org/ticket/2725
> When setting up a map with fractionalZoom: true and a PanZoomBar control
> with forceFixedZoomLevel: true there seems to be a bug in the
> implementation. If you start at a fixed zoom level and use the zoombar
> slider you will get a fixed zoom level back (i.e. start from 2 move up 3 get
> 5). But if you start with a non fixed zoom level you will get a non fixed
> back (i.e. start from 2.345 move up 3 get 5.345). Maybe this is the way
> somebody wanted it to be, but for me it feels a bit broken. Also there is an
> error when you move the slider to the bottom of the bar. Then it returns a
> negative zoom level and can not zoom to it. In the attached patch I fixed
> both issues so that you will get back a fixed level and 0 as the minimum
> zoom level.
More information about the Dev
