[OpenLayers-Dev] PanZoomBar doesn't handle forceFixedZoomLevel correct
Fabian Patzke (OL) listensammler at patzi.de
Thu Jul 15 03:06:53 EDT 2010
Hi, sorry it took so long, but I had to much stuff around my had ;)
Marc Jansen-2 wrote:
> It was me that provided the forceFixedZoomLevel-patch in the first place
> (see http://trac.openlayers.org/ticket/2288) and it was (at least by me)
> never intended to show the behaviour you describe. Could you please add
> tests to your ticket (http://trac.openlayers.org/ticket/2725) that fail
> without your patch and pass with your patch applied?
Is there anywhere a document describing how a test should be written for OL?
I do not know how to handle the UI parts of a test. Or do you mean I should
just write a small map application in which you can reproduce that
behaviour?
Greetings,
Fabian
View this message in context: http://osgeo-org.1803224.n2.nabble.com/PanZoomBar-doesn-t-handle-forceFixedZoomLevel-correct-tp5259463p5296155.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
