[OpenLayers-Dev] constructor signatures
Tim Schaub
tschaub at opengeo.org
Fri Jun 18 10:41:22 EDT 2010
Gregers Gram Rygg wrote:
> How about max 3 arguments for any constructor or method in 3.0? Need
> more arguments, use an options object.
The problem with rules like this (max of X) is that we don't know ahead
of time how many properties we'll want to use when configuring a new
instance. We don't know how many will be required. We don't know how
many will be optional. In the lifetime of a major version, the
configuration logic of a constructor changes.
You could say that when adding a new constructor, it cannot have more
than three arguments, and that the third one *has* to be an object that
can later accept any number of member properties.
I think three is arbitrary (and silly). If we accept that we'll learn
more than we know now and that our code will change in the lifetime of a
major version, going with a single argument is the simplest way to allow
backwards compatibility without having weird (null, null, config)
constructors.
> The only downside I see with options objects are that it gets more
> difficult to read the source code to see what the available options
> are. One approach to solve this would be to use fake option classes
> for Natural Docs.
> * options - {GridLayerOptions} Hashtable of extra options to tag
> onto the layer
> Then document the GridLayerOptions in the same file (bottom?):
> * Class: GridLayerOptions
> * Inherits: <LayerOptions>
> * Properties:
> * name - {String} *required*
> * url - {String} *required*
> * params - {Object} *required*
> It will be difficult to keep the arguments up to date for the class
> you inherit from, but maybe it is enough to just document the options
> specific for this class, and link to the inherited options "class"
> somehow. I'm not very familiar with NaturalDocs, so I don't know if
> "Class" is the best keyword for the options object, but I like it
> better than some of the docs today (see RootContainer's constructor).
> This is similar to what Google Maps does in their documentation:
> http://code.google.com/apis/maps/documentation/javascript/reference.html#MapTypeControlOptions
> Options objects can have required properties. Just throw an Error if
> it's missing. Maybe a required options array on the prototype, so it
> can be done in a generic manner.
> Errors thrown from a minified script is quite useless, since it
> doesn't say anything about class name or line number in original
> source. Maybe it's time to integrate a simple logging framework? Can
> start a separate thread to discuss this.
> Best regards,
> Gregers
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
More information about the Dev
