[OpenLayers-Dev] constructor signatures
Tim Schaub
tschaub at opengeo.org
Fri Jun 18 11:23:12 EDT 2010
Gregers Gram Rygg wrote:
> How about max 3 arguments for any constructor or method in 3.0? Need
> more arguments, use an options object.
> The only downside I see with options objects are that it gets more
> difficult to read the source code to see what the available options
> are. One approach to solve this would be to use fake option classes
> for Natural Docs.
> * options - {GridLayerOptions} Hashtable of extra options to tag
> onto the layer
> Then document the GridLayerOptions in the same file (bottom?):
> * Class: GridLayerOptions
> * Inherits: <LayerOptions>
> * Properties:
> * name - {String} *required*
> * url - {String} *required*
> * params - {Object} *required*
I totally agree that we need to improve things on the documentation
side. We'll need to settle on some documentation conventions to make
things easier.
Given our current setup, compare how I documented the WMTS constructor
to how the WMS constructor is documented.
WMTS:
http://dev.openlayers.org/apidocs/files/OpenLayers/Layer/WMTS-js.html#OpenLayers.Layer.WMTS.OpenLayers.Layer.WMTS
WMS:
http://dev.openlayers.org/apidocs/files/OpenLayers/Layer/WMS-js.html#OpenLayers.Layer.WMS.OpenLayers.Layer.WMS
If I didn't know already, I'd find it very hard to figure out that the
"layers" param is required for the WMS layer to work. The same goes for
the TMS layer and others that followed this convention of having
strictly required properties buried as properties of an object that is
the second or third argument to the constructor.
Granted, the issue above is strictly a documentation one. And we could
(really should) go with lists of lists for these multiple argument
constructors that have required properties in the second or third
arguments. But I think our documentation challenge will be easier with
a single argument constructor.
> It will be difficult to keep the arguments up to date for the class
> you inherit from, but maybe it is enough to just document the options
> specific for this class, and link to the inherited options "class"
> somehow. I'm not very familiar with NaturalDocs, so I don't know if
> "Class" is the best keyword for the options object, but I like it
> better than some of the docs today (see RootContainer's constructor).
> This is similar to what Google Maps does in their documentation:
> http://code.google.com/apis/maps/documentation/javascript/reference.html#MapTypeControlOptions
> Options objects can have required properties. Just throw an Error if
> it's missing. Maybe a required options array on the prototype, so it
> can be done in a generic manner.
> Errors thrown from a minified script is quite useless, since it
> doesn't say anything about class name or line number in original
> source. Maybe it's time to integrate a simple logging framework? Can
> start a separate thread to discuss this.
> Best regards,
> Gregers
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
More information about the Dev
