[OpenLayers-Dev] problems on deactivate DrawFeature Control
after feature added
Frederic Junod
frederic.junod at camptocamp.com
Tue Jun 22 09:47:34 EDT 2010
Hello,
Thanks for reporting this issue, I've opened a ticket:
http://trac.openlayers.org/ticket/2701
Please test if it works for you.
fredj
On Tue, Jun 22, 2010 at 1:02 PM, Vito Tafuni <vito at vitotafuni.com> wrote:
> I have this error when i try to deactivate the DrawFeatureControl (on
> featureadded event) using a RegulaPolygon Handler
> Error: this.layer is null
> Source File: .../openlayers/lib/OpenLayers/Handler/RegularPolygon.js
> Line: 382
> the problem is not present if using Polygon Handler
> i've found a very old question (~2008) like this on users mailing list
> but no answer on the right way to deactivate the controller
> thanks
> -Vito-
> Tafuni Vito
> "Verba volant, scripta manent... data corrupted"
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Frédéric Junod
Camptocamp SA
More information about the Dev
