[OpenLayers-Dev] TransformFeature transformcomplete event has a
wrong feature attached
Fabian Patzke (OL)
listensammler at patzi.de
Mon Jun 28 08:16:05 EDT 2010
The feature that is attached to the transformcomplete event is not the
transformed feature as stated in the documentation. Instead the event
feature is a LineString (the one that builts the box around the feature), if
you move the original feature, or a Point (the one you used for moveing the
node), if you turn/resize it.
I have created a ticket http://trac.openlayers.org/ticket/2714 and a
solution is provided as patch attached to the ticket.
Please have a look at it.
Greetings,
Fabian
View this message in context: http://osgeo-org.1803224.n2.nabble.com/TransformFeature-transformcomplete-event-has-a-wrong-feature-attached-tp5230537p5230537.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev
