[OpenLayers-Dev] Conflict of jquery tabs and openlayers.
Roald de Wit
list at rdewit.net
Wed Jun 30 07:08:13 EDT 2010
There could be a few causes. Try searching for the combination of jQuery
and OpenLayers in the openlayers-users list [1] for similar problems and
solutions. That is also the list where these kind of problems should be
discussed. The openlayers-dev list is for discussing the internals of
OpenLayers, not (the problems with) using of it.
If your search does not result in anything useful, I advise you to
create a minimal example and ask your question again (with that example)
on the users list.
Regards,
Roald
[1] http://openlayers.org/mailman/listinfo/users
On 30/06/10 20:30, Iswaria wrote:
> Hi,
> I am using jquery tabs and openlayers. In Firefox, the map is not loaded and
> in IE the map is loaded properly. It is showing centerpx is null or size is
> null, javascript errors.
> IF i remove the jquery libraries, the map is loaded properly in both the
> browsers.
> Can anyone tell me, how to solve this conflict between jquery and
> openlayers.
> Thanks,
> Iswaria
More information about the Dev
