[OpenLayers-Dev] Using xy: false with Protocol.WFS
Steven Ottens
steven at minst.net
Wed Jun 30 11:30:32 EDT 2010
Hi All,
I'm trying to swap the x and y of coordinates for one specific WFS layer. The layer is defined as:
skGN : new OpenLayers.Layer.Vector("Norway GN",
strategies: [new OpenLayers.Strategy.BBOX({resFactor: 1})],
visibility: true,
styleMap: GeoViewer.Styles.pointStyles,
projection: new OpenLayers.Projection("EPSG:4258"),
protocol: new OpenLayers.Protocol.WFS({
version: "1.1.0",
outputFormat: "text/xml; subtype=gml/3.2.1",
srsName: "EPSG:4258",
extractAttributes:true,
url: GeoViewer.Catalog.urls.SK_WFS,
featurePrefix: "gn",
featureType: "NamedPlace",
featureNS: "urn:x-inspire:specification:gmlas:GeographicalNames:3.0",
geometryName: "geometry",
maxFeatures: "50",
schema: "http://esdin.geodan.nl/fgi/SK/deegree2-wfs/services?service=WFS&version=1.1.0&request=DescribeFeatureType&typeName=GN:NamedPlace&namespace=xmlns=(GN=urn:x-inspire:specification:gmlas:GeographicalNames:3.0)"
I noticed that xy is a parameter of Format.WFST.v1and changing xy: true to xy: false in code does what I want. However, it does that for all layers and that's not what I want. Is it possible to configure one layer to swap xy, using the approach above?
I tried to add xy: false after visibility: true and in the protocol definition (which obviously doesn't work).
Is there a way to send attributes to the correct Format class?
Regards,
Steven
More information about the Dev
