[OpenLayers-Dev] Using xy: false with Protocol.WFS
Bart van den Eijnden
bartvde at osgis.nl
Wed Jun 30 11:34:23 EDT 2010
Use formatOptions on the protocol.
Best regards,
Bart
On Jun 30, 2010, at 5:30 PM, Steven Ottens wrote:
> Hi All,
> I'm trying to swap the x and y of coordinates for one specific WFS layer. The layer is defined as:
> skGN : new OpenLayers.Layer.Vector("Norway GN",
> strategies: [new OpenLayers.Strategy.BBOX({resFactor: 1})],
> visibility: true,
> styleMap: GeoViewer.Styles.pointStyles,
> projection: new OpenLayers.Projection("EPSG:4258"),
> protocol: new OpenLayers.Protocol.WFS({
> version: "1.1.0",
> outputFormat: "text/xml; subtype=gml/3.2.1",
> srsName: "EPSG:4258",
> extractAttributes:true,
> url: GeoViewer.Catalog.urls.SK_WFS,
> featurePrefix: "gn",
> featureType: "NamedPlace",
> featureNS: "urn:x-inspire:specification:gmlas:GeographicalNames:3.0",
> geometryName: "geometry",
> maxFeatures: "50",
> schema: "http://esdin.geodan.nl/fgi/SK/deegree2-wfs/services?service=WFS&version=1.1.0&request=DescribeFeatureType&typeName=GN:NamedPlace&namespace=xmlns=(GN=urn:x-inspire:specification:gmlas:GeographicalNames:3.0)"
> I noticed that xy is a parameter of Format.WFST.v1and changing xy: true to xy: false in code does what I want. However, it does that for all layers and that's not what I want. Is it possible to configure one layer to swap xy, using the approach above?
> I tried to add xy: false after visibility: true and in the protocol definition (which obviously doesn't work).
> Is there a way to send attributes to the correct Format class?
> Regards,
> Steven
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev
