[OpenLayers-Dev] SOS support
Bart van den Eijnden bartvde at osgis.nl
Thu Mar 25 10:12:16 EDT 2010
Hi Xurxo,
please file a trac ticket with the attached patch. TIA.
http://trac.openlayers.org/register
Best regards,
Bart
On Mar 25, 2010, at 3:07 PM, Xurxo Mendez wrote:
> Hi again.
> I noticed that the class v1_0_0 (from SOSCapabilities) expects only one observedProperty per ObservationOffering. In my project I needed to read more than one observedProperties from one single offering as my server writes that, so I modified a little code in that class to make it able to read more than one observedProperty per Offering. I don't know if that's a bug (in such a case I don't know if this is the place where I should notify you), if it's already being considered or if it's just another aspect that I'm not aware of. The modified code works well, so if anyone wants to see or check it just mail me. Thank you in advance
> Best regards
> Xurxo Méndez Pérez
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev mailing list
