[OpenLayers-Dev] Fatal error at startup when the URL has special characters
Xavier Mamano (jorix) xavier.mamano at gmail.com
Tue May 4 16:33:36 EDT 2010
Hi list,
It is an old error in OpenLayers (see #1704, #2540 ...) now occurs in all
browsers (EI8, FF, CH, Safari). You can try http://openlayers.org/?q=%E1
In #1704 there was an almost philosophical debate. But without a good
solution, at least, it would be appropriate to make a simple "try...catch"
statement and  losing only one parameter, not a map!
It would be desirable for proper internationalization.
Jorix
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Fatal-error-at-startup-when-the-URL-has-special-characters-tp5005498p5005498.html
Sent from the OpenLayers Dev mailing list archive at Nabble.com.
More information about the Dev mailing list
