[OpenLayers-Dev] Can OpenLayers call a webservice?
Phil Scadden
p.scadden at gns.cri.nz
Fri May 7 00:42:13 EDT 2010
> Do you have any example which explains the how to use/call XML data
> with OpenLayers?
Look at the openlayerss Examples. http://www.openlayers.org/dev/examples/
Filter for GML, then filter for XML, also look at the KML examples.
Should you give a number of options.
Phil Scadden, Senior Scientist GNS Science Ltd 764 Cumberland St,
Private Bag 1930, Dunedin, New Zealand Ph +64 3 4799663, fax +64 3 477 5232
Notice: This email and any attachments are confidential. If received in error please destroy and immediately notify us. Do not copy or disclose the contents.
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20100507/e0c69006/attachment.html
More information about the Dev
