[OpenLayers-Dev] SLD Select Control Bug
Bart van den Eijnden bartvde at osgis.nl
Fri May 7 11:49:17 EDT 2010
FYI, this has been fixed. The code has also been committed to trunk.
http://www.openlayers.org/dev/examples/SLDSelect.html
Best regards,
Bart
On Apr 24, 2010, at 7:17 PM, Debasish Sahu wrote:
> There seems to be bug with the SLD Select control .See the attached image.
> If I select the SLD Select with point option and Cities as the selection layer , the control selects all of the Cities features where as it should have selected just
> the one that I have circled in blue since that was the feature that I had clicked.
> Thanks and Warm Regards
> Debasish Sahu
> <select.gif>_______________________________________________
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev mailing list
