[OpenLayers-Dev] tiling behaviour
toni hernández
tonidelacalle at gmail.com
Sat May 8 07:56:11 EDT 2010
max number of tiles
Hi list,
I am using a wms layer on a map. Every time I reload the map, I get a quite
incomplete map. That's because the wms server doesn't render more than 4
or 5 tiles. In fact it renders all the tiles but some of them are just pink
images. As it renders every tile I can not detect any error but still my map
is incomple.
First I tried the singleTile property (with ratio:1) but again if the tile
is too big I get the pinky image.
Then I tried bigger tiles combined with buffer:0 property (so no unnecessary
tiles are asked).
I was expecting this to be the best option but then I realized that
openlayers defines (at least by default) more tiles than strictly necessary.
Some of the tiles are mostly out of the map.
Is there a way to prevent this tiling behavior?
thanks.
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20100508/531e5892/attachment.html
More information about the Dev
