[OpenLayers-Dev] visualizing gml V3 layers from gml file with openlayers
ourahou amine infolcop at gmail.com
Mon May 10 11:56:56 EDT 2010
Hi ,
i would like to display a gml v3 layer from a gml file with openlayers. so
whene i use  this code whith the simple GML format.like this :
var gmllayer= new OpenLayers.Layer.GML("amine","gml/services.xml",{
            projection: new OpenLayers.Projection("EPSG:4326"),
     format:  OpenLayers.Format.GML,
      formatOptions: {
         extractAttributes: true
                styleMap: new OpenLayers.StyleMap({
                    "default": new
OpenLayers.Style(OpenLayers.Util.applyDefaults({
                        externalGraphic: "am.png",
                         graphicOpacity: 1,
                        rotation: 45,
                        pointRadius: 7
                    }, OpenLayers.Feature.Vector.style["default"])),
                    "select": new
                      externalGraphic: "../img/marker-blue.png",
                        fillColor: "gray"
                    }, OpenLayers.Feature.Vector.style["select"]))
the result in the map is like a disperse polygones, because the real gml
format in my file is multisurface and surface (new format for gml V3).
and whene i specifie the format  format:  OpenLayers.Format.GML.V3 like
this, i got nothing  without success ,
var fir= new OpenLayers.Layer.GML("amine","gml/services.xml",{
      format: OpenLayers.Format.GML.v3,
     formatOptions : {
     surface: true,
             featureType: "fir",
             featureNS:"xmlns(app=http://www.deegree.org/app)",
             geometryName: "geom",
              srsName: "EPSG:4326",
              schemaLocation: "http://schemas.opengis.net/wfs/1.1.0/wfs.xsd"
please if someone knows how to display a gml V3 layers with openlayers ,i 'm
using deegree server and gml v3 is a response for deegree WFS v 1.1.0.
thanks to reply.
URL: http://lists.osgeo.org/pipermail/openlayers-dev/attachments/20100510/23fd3355/attachment.html
More information about the Dev mailing list
