But I used the same html example, I remove the proxyHost, and connect to ArcIMS server, which is not on my machine. I run the example on IE and it works fine -- View this message in context: http://osgeo-org.1803224.n2.nabble.com/ArcIMS-tp5056734p5056872.html Sent from the OpenLayers Dev mailing list archive at Nabble.com.
