[OpenLayers-Dev] r10347
Tim Schaub tschaub at opengeo.org
Fri May 21 20:12:45 EDT 2010
Hey-
I think it would make sense to revert r10347 and look for a different
solution.
It looks to me like that change is not specific to IE at all, but
instead to any response that doesn't contain a Date header.
To see the effect, you need a server that doesn't include the Date
header in the response.  Then open up Firebug and run the following.
     OpenLayers.Request.POST({url: "foo", data: "bar"})
You should see two requests issued.  The first from XMLHttpRequest.js
line 222 and the second (with no data) from line 190.
Tim
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
More information about the Dev mailing list
