[OpenLayers-Dev] [Bug] IE8:XML.js Attributes with null-value
Tim Schaub
tschaub at opengeo.org
Tue May 25 12:32:46 EDT 2010
Dipl. Inf. Carsten Eider wrote:
> Hi list,
> when serializing features with null values on attributes on IE8,
> then there is a exception in XML.createTextNode.
> Line 247 "node = this.xmldom.createTextNode(text);" fails,
> as text is a null-Object.
> Placing "if (text==null) text='';" before works fine.
Could you create a ticket with a description of this issue? We made a
change some time ago related to this, and I'd like to keep the logic
consistent with regard to handling null values.
Please specify what format you are using to serialize features.
Thanks,
Tim
> Any better suggestions?
> FF works fine!
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
More information about the Dev
