[OpenLayers-Dev] CCLA from RealGo
Roald de Wit list at rdewit.net
Mon May 31 01:33:56 EDT 2010
Off-list answer from Chris Schmidt:
On 31/05/10 05:09, christopher.schmidt at nokia.com wrote:
 > yep.
 > -- Chris
One more thing: the CLA forms ([1], [2]) still reference MetaCarta. Has
anything changed (like address or fax number) since MetaCarta's
acquisition by Nokia?
Regards, Roald
[1] http://www.openlayers.org/ccla.txt
[2] http://www.openlayers.org/icla.txt
On 29/05/10 15:32, Roald de Wit wrote:
> Hi,
> While the topic is still hot: what if somebody that has contributed in
> the past (using a CCLA) now works for another organisation that doesn't
> have a CCLA (yet)? I assume that that a representative of that
> organisation will need to send in a CCLA for that person to continue
> contributing or otherwise, that person would need to send in an ICLA?
> Regards, Roald
> On 28/05/10 22:45, christopher.schmidt at nokia.com wrote:
>> In general, CCLAs are designed to offer a relatively sane way of
>> ensuring that contributors for an organization are covered. Listing
>> each individual name is handy simply for the association from
>> individual to contribution. If there is a new person who Camptocamp
>> wants covered, an informal mention on a mailing list (like this one)
>> is sufficient; so basically, the process is "Edit the wiki", if you're
>> sure camptocamp is okay with that :)
>> Regards,
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
More information about the Dev mailing list
