[OpenLayers-Dev] OpenLayers license and copyright notice
Tim Schaub tschaub at opengeo.org
Wed Nov 3 18:39:18 EDT 2010
Hello-
It's is good to see that you are using OpenLayers in your Map World
application (http://www.tianditu.cn/map/index.jsp).
We notice that you are not including an indication of the OpenLayers
Contributors' copyright or the disclaimer included in our license file:
http://svn.openlayers.org/trunk/openlayers/license.txt
The easiest solution would be to use the text of this license file in
its entirety at the head of your JavaScript code.
http://www.tianditu.com/js/GeoSurfJSAPI/GeoSurfJSAPI.js
Please let us know if we can further assist you in complying with the
terms of the OpenLayers license - our intention is to make it easy to
build and distribute applications with OpenLayers.
Thanks,
Tim (one of the OpenLayers contributors)
Tim Schaub
OpenGeo - http://opengeo.org
Expert service straight from the developers.
More information about the Dev mailing list
