[OpenLayers-Dev] Re: Dev Digest, Vol 50, Issue 13
Matt Priour mpriour at kestrelcomputer.com
Mon Nov 15 12:50:38 EST 2010
you can put it there or, even better, use an OpenLayers proxy host. There
are python, cgi, & jsp versions of the proxy. proxy.jsp & proxy.cgi are both
available from the OpenLayers svn repository.
There are also .net versions of this (ESRI has one available for download.
lookup arcgis js proxyhost. you would need to edit it to look for and accept
the url parameter)
The reasons you need this and more information about using it is available
from the openlayers wiki
http://trac.osgeo.org/openlayers/wiki/FrequentlyAskedQuestions#ProxyHost
Matt Priour
Kestrel Computer Consulting
Sent: Monday, November 15, 2010 11:00 AM
To: <openlayers-dev at lists.osgeo.org>
Subject: Dev Digest, Vol 50, Issue 13
> Send Dev mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
> http://lists.osgeo.org/mailman/listinfo/openlayers-dev
> or, via email, send a message with subject or body 'help' to
> openlayers-dev-request at lists.osgeo.org
> You can reach the person managing the list at
> openlayers-dev-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Dev digest..."
> Today's Topics:
>   1. Re: Adding "Basicmap" to an asp page. (DaddyMagic)
> Message: 1
> Date: Sun, 14 Nov 2010 11:39:49 -0800 (PST)
> From: DaddyMagic <andrew.f.davis at saic.com>
> Subject: [OpenLayers-Dev] Re: Adding "Basicmap" to an asp page.
> To: dev at openlayers.org
> Message-ID: <1289763589516-5738105.post at n2.nabble.com>
> Content-Type: text/plain; charset=us-ascii
> Hi,
> I have gotten my map to display on the default.asp page and am happy with
> the map so far.  I am having trouble with my server requests.
> Do I need to build my page inside Geoserver itself to run my
> GetFeatureInfo
> Requests?
> I notice that all of the demo maps within GeoServer are
> "http://localhost8080....." and they all work fine.  I built my page
> inside
> my "MyDocuments" using VisualWeb Developer Express 2010.
> The map loads and all of the layers display, but the address bar is
> outside
> of the "localhost8080" address, and all of the GetFeatureInfo requests are
> being ignored.
> Where inside of the GeoServer folders should I build my website?
> C:\Program Files\apache-tomcat-6.0.29\webapps  ??
> Andy.
> http://osgeo-org.1803224.n2.nabble.com/Adding-Basicmap-to-an-asp-page-tp5592279p5738105.html
> Sent from the OpenLayers Dev mailing list archive at Nabble.com.
> Dev mailing list
> Dev at lists.osgeo.org
> End of Dev Digest, Vol 50, Issue 13
More information about the Dev mailing list
