[OpenLayers-Dev] SelectFeature control interfering with popup
Eric Lemoine
eric.lemoine at camptocamp.com
Tue Nov 16 02:59:54 EST 2010
On Monday, November 15, 2010, dr <rykovd at gmail.com> wrote:
> My map contains SelectFeature Control with enabled hover:true property.
> By onSelect property I call function which put OpenLayers.Popup on my map.
> By onUnselected - remove popup from map. Popup is used like tooltip. But
> when I place mouse cursor over popup - selected feature becomes unselected.
> How to prevent this behavior?
The simplest might be to programatically reselect the feature when the
mouse goes over the popup.
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
More information about the Dev
